Using a 2-channel am for inside speakers
  • 2
CrazeFuol
I am not too sure on how to do this, but how do I wire my 2 channel amp so I can run my door speakers. The person that put it in only put it in my two back speakers because it was easy access, I told him that I would do the rest... but I just remembered that I do not know how to do it...
Can someone tell me how to ?
Originally posted by CrazeFuol I am not too sure on how to do this, but how do I wire my 2 channel amp so I can run my door speakers. The person that put it in only put it in my two back speakers because it was easy access, I told him that I would do the rest... but I just remembered that I do not know how to do it...
what speaker do you have? how many ohms are they?
Originally posted by CrazeFuol I have some Sony speakers my friend gave me... the are 61/2"... but I am not too sure about the ohms
well don't worry I doubt they are 2ohms anywaywhat you'll have to do it run another pair or speaker wires from the amp to the nearest place for connection to the fronts------------ either to the radio---------- or to each door
radio would be simple.
733
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
594
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I hold firm on the deposit in all situations 😎
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know. Cheers !
CrazeFuol
CrazeFuol
Miami, FL
chris229
    May 18, 2024
    May 18, 2024
