Using 4 gauge to wire capacitor on 1/0 gauge system?
Thanks everyone for all your advice. Ive learned alot from everyone here. A lot of stuff finally makes sense now. All the shops i go to are always trying to push me to buy caps and all kinds of junk that makes me doubt. Thats why i cOme here. Its truly appreciated.
Want to learn to do stuff correctly an stop trying to cut corners. Far from being on your nuts. I have no worries that whenever I wanna play my system, I know my car wont burn. You on the other hand is just a matter of time.
If i fry my car, system or whatever happens to me is My problem not yours. Since when is it wrong to ask? Ill ask if i want to and if you dont like it, then thats your issue.
XSTATIC BATCAP MODEL 400 | eBay
NEW SHURIKEN SK-BT20 20 AH CAR AUDIO BATTERY | eBay
SHURIKEN SK-BT35 Battery w/ 35AH and 950 Cranking Amps | eBay
NEW KINETIK KHC800 CAR AUDIO BATTERY CELL KHC-800BLUE | eBay
all good batteries
or even better buy some deka's on here
http://www.caraudio.com/forums/electrical-wiring-classifieds/506110-bad4healths-deka-c-d-batteries-thread.html
this would give u plenty of power, id then put an isolator on it. and run your system strictly off the deka and alternator so it wont destroy your front battery, problem is that standared batteries dont last long if their discharged and charged a lot. the isolator and this deka will prolong your front batteries life.
Thanks ill definetly look into this
why ask and waste our time if you're not listening to what we tell you? if you're going to ghetto it up, fine. don't waste our time asking how to do it. sometimes //content.invisioncic.com/y282845/emoticons/search.gif.e79a63b2b580b39b282dff402646b704.gif goes a long way bro.
Who said i wasnt listening? All i did was ask about certain topics and maybe learn a thing or two. I never said i was going to do every single thing i ask about. Whenever i go to a shop i just ask and the first thing they say is "oh you need a capacitor. $100" or " you dont need a capacitor. You need this special battery. $300" or " you dont need a battery. What you need is for us to look and diagnose your problem. $65" and "oh i see thr problem, you dont have a capacitor", which leads me to "wtf". so i come here to ask and get some honest answers. Hope you see where im coming from
Oh while im here, i was wondering how would i go about wiring my door speakers to an amp? Its a two channel amp i believe. My HU has 3 rca outputs for the SW,R,F. This has me abit confused. Do the speakers go directly to the amp or what? Thanks
just the door speakers? as in 2 speakers? just wire up the amp, pull wire from amp to speakers. run RCAs off HU to amp (use F output on HU)
Actually all of them (4). Do i bridge all positives and all negatives on the 4 speakers and plug to amp using the (+) and (-)?
no. to do that you need to know what the lowest load the amp can handle, and what the final load of all the speakers is. you would really rather have a 4ch amp for all 4 speakers
your door speakers are probably 4 ohm. if you wire them together you get either 2 or 8 ohms. i doubt your 2ch will push both channels at 2 ohms each. and if you go to 8 ohms you loose all your power from the amp. either 2x 2ch or a 4ch. or just amp the front and have the HU power the rears. or just disconnect the rears.
marquisbrah
marquisbrah
fresno cali
jco1385
