US AMPS True power?
Two Channel Class AB Amplifier
Total Power Output: 375 Watts RMS
THD at Rated Power:
Stereo Separation: >98dB
Signal/Noise Ratio: 105dBA
Frequency Response: 5Hz-50KHz
Fuse Rating: 75 Amps
Dimensions: (Including Terminals)
62mm / 2.44in High
229mm / 9.0in Wide
368mm / 14.50in Long
Weight: 3.63kg / 8.00lb
Variable 24dB Low-Pass Active Crossover
One-Half Ohm Stable
25 Watts x 2 into 4 Ohms
33 Watts x 2 into 3 Ohms
50 Watts x 2 into 2 Ohms
100 Watts x 2 into 1 Ohm
185 Watts x 2 into ½ Ohm
100 Watts Bridged into 4 Ohms
132 Watts Bridged into 3 Ohms
200 Watts Bridged into 2 Ohms
375 Watts Bridged into 1 Ohm
These are the ratings, but as we all know OS amplifiers ratings tend to be uhm QUITE underrated. I'd say at least multiply whatever the ratings are by about 1 to 1.5 x the listed rating. In most cases it might even be around 2 x the power...
Specs for 92 U.S.AMPS USA-50HC are as follows:
Number Of Channels-2
POWER PER CHANNEL
4ohm-25
2ohm-50
1ohm-100
.5ohm-150
TOTAL HARMONIC DISTORTION IMD SIGNAL TO NOISE RATIO 110db
FREQUENCY RESPONSE 5HZ/50KHZ
SLEW RATE 150Vus
INPUT SENSITIVITY 250mv/10v
VARI-LOUD -NO
PREAMP OUTPUTS -NO
ACTIVE CROSSOVER -NO
FUSE 25A
DIMENSIONS 7.7X2.3X12
DAMPING FACTOR 500
This is out of my 92 catalog
terra
terra
Yes
Earthman
