US AMPS True power?
terra
Yes
Thinking of buying a US Amp 50HC....the 1992/1993 model i believe.
does anyone know what this amp actually benches at? lookin for some true rms power...not the "rated" power.
thanks
Two Channel Class AB Amplifier
Total Power Output: 375 Watts RMS
THD at Rated Power:
Stereo Separation: >98dB
Signal/Noise Ratio: 105dBA
Frequency Response: 5Hz-50KHz
Fuse Rating: 75 Amps
Dimensions: (Including Terminals)
62mm / 2.44in High
229mm / 9.0in Wide
368mm / 14.50in Long
Weight: 3.63kg / 8.00lb
Variable 24dB Low-Pass Active Crossover
One-Half Ohm Stable
25 Watts x 2 into 4 Ohms
33 Watts x 2 into 3 Ohms
50 Watts x 2 into 2 Ohms
100 Watts x 2 into 1 Ohm
185 Watts x 2 into ½ Ohm
100 Watts Bridged into 4 Ohms
132 Watts Bridged into 3 Ohms
200 Watts Bridged into 2 Ohms
375 Watts Bridged into 1 Ohm
These are the ratings, but as we all know OS amplifiers ratings tend to be uhm QUITE underrated. I'd say at least multiply whatever the ratings are by about 1 to 1.5 x the listed rating. In most cases it might even be around 2 x the power...
Specs for 92 U.S.AMPS USA-50HC are as follows:
Number Of Channels-2
POWER PER CHANNEL
4ohm-25
2ohm-50
1ohm-100
.5ohm-150
TOTAL HARMONIC DISTORTION IMD SIGNAL TO NOISE RATIO 110db
FREQUENCY RESPONSE 5HZ/50KHZ
SLEW RATE 150Vus
INPUT SENSITIVITY 250mv/10v
VARI-LOUD -NO
PREAMP OUTPUTS -NO
ACTIVE CROSSOVER -NO
FUSE 25A
DIMENSIONS 7.7X2.3X12
DAMPING FACTOR 500
This is out of my 92 catalog
225
448
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
terra
terra
Yes
Earthman
SPLBassJunkie
    May 21, 2024
    May 20, 2024
