US Amps Merlin Series II MD1D 1200watt Monoblock (Original Design) Canada or US
darren700
got bu/\/\p?
1 x 300rms @4ohm
1 x 600rms @2ohm
1 x 1200rms @1ohm
Built-In Electronic Crossover, Selectable 24dB per octave butterworth (adjustable 40-250 hz)
24dB Subsonic Filter 15-40 HZ
Bass EQ 30 dB @ 45 HZ
Low level RCA input
Block power connector
requires 4 gauge power and ground wires (can use 1ga)
8 - 18 gauge speaker wire inputs
Aluminum heatsink
Screw terminal speaker connectors
Convention cooling system
Digital Class D efficient power supply
Frequency Response: 20 Hz - 250 Hz
Free bass remote included!
3 x 30A fuses!
Ran this amp for the past 3 years without a single problem.
runs great, never goes into protection, was amazing with my stereo integrity mag 15, and gave my 18" Zcon quite a workout too!
only selling beacuse i upgraded to a Audioque 2200d for my Zcon 18.
Notes about the amp:
-Speaker outputs were stripped so i tapped them 1/4-20NC and put new set screws in. good as new.
-Bought a brand new cable for the remote as the other one broke when trying to remove it from my truck.
-There is some marks on the end from mounting.
-Bass remote included
Cosmetic: 7/10
Mechanical: 10:10
210 Shipped.
-I am located in Canada.
-I can ship to Canada or US. Note: if shipping to US, i will cross the border and ship it to avoid brokerage fees for the buyer
-Shipping will be fully insured, tracked, and signature required.
-will be shipped in box from MD23.
Thanks!
151
413
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
darren700
got bu/\/\p?
darren700
Windsor, Ontario, Canada
xctrack
    May 16, 2024
    May 16, 2024
