US AMPS MD2D fs\trade
bigblackdodge
US AMPS MD2D merlin series
US AMPS MERLIN SERIES MD2D MONO
RMS 400W x 1 @ 4ohms
RMS 850W x 1 @ 2ohms*
RMS 1800W x 1 @ 1ohm*
Low-Pass : 40Hz-250Hz -24db/Oct
Sub Sonic : 15Hz-40Hz*-24db/Oct
Frequency Response: 20Hz to 250Hz +/- 1.0 db
Dimension: 9"W x 2.5"H x 21"L
Lookd good 8.5/10 see in pic were seat rubbed black paint off edge.
Performs perfect 9.5/10 (one speaker terminal screw has a little slop but will tighten. It a mono with 2 separate outputs so I use the good one.
$225.00 shipped OBO/trade for a bigger amp 2kw, or meaty sub(s)
Im not seeing anywhere that amp does 1800, says it does 1500 just an FYI so people dont bash you cause they think you are lying. Great price if ya cant sell it let me know im interested
I stand corrected; The amp has 3x40A fuses and at 1 ohm is rated @1500W @ 14.4V Certified.
And as a personal done test. I am currently wired at 2ohms and I got 756W on a solid music tone dropping to 13.1V. And I have been informed it is the V1 Merlin Series.
Md2D4ohm @ 12v 1x300
4ohm @ 14.4v 1x550
2ohm @ 14.4v 1x1000
1ohm @ 14.4v 1x1500
This is directly from the manual http://www.reaudio.com/documents/md_manual[2006].pdf
---------- Post added at 05:06 PM ---------- Previous post was at 05:05 PM ----------
****** amp nonetheless. And I am pretty sure they were underrated
Thankyou sir! The 756W that I posted is without knowing ohm rise so 1000@ 2ohm is a possibility then i assume
bigblackdodge
bigblackdodge
Morven, Ga
bigblackdodge
