It should do close to rated power.
90a X 75% X 14.4v = 972 watts
I went 75% efficiency because most class d amps are close to 75% efficient at a 1 ohm load. Also a fuse can blow above 90a if the current flows through it for a fraction of a second, so it might do a little bit more than 972 watts before it will pop those fuses or if its a bit better than 75% efficient at 1 ohm. Sorry I do not have a bench test result, I just did a estimation of it's out put power but the fuse rating.
