Unequal voltage??
RoYALbLUE08
Whatsup guys. I noticed my amplifier is giving unequal voltage. The right side is giving about 2 volts higher than my left side??? Any ideas of why? Maybe it's defective??
The left side gets between 15.7-17.9 volts and the right gets between 18.3-19.8 volts continuously I measured it using a DMM
In my car I can tell a difference the right side is alot louder so I have to fade my headunit to the left by like 2 notches
This is with 2 amplifiers that I have both from precision power in 2 different cars.
One of em is ppi black ice bk800.4 ( love this amp!)
The other is an older Sedona s580.4
Its more likely to be a problem with ur lc2i but at any rate since you aren't ruining time alignment just put your mids on those more powerful channels. You can check and see if the amp is wrong by simplest moving the RCAs around and checking output on the amp at the same time. But I'd guess that the lc2i has one of the gain pots a little higher than the other
RoYALbLUE08
RoYALbLUE08
NYC
winkychevelle
