Um I'm Clipping, Y
yeah but clipping=distortion right ? or is clipping not audible to the human ear ?
Clipping causes distortion. Distortion is a byproduct of clipping, it is not clipping itself. To be picky.
Its audibility depends on many things. The distortion type (even vs odd order), the sound threshold the distortion is 'competing' with for audibility, and frequency all play major roles in how easy it is to hear distortion. This case, of course, is odd order harmonic distotion, so that excludes one of the conditions.
according to the dmm method i wasnt' even close to clipping, it was reading 48.9 which 74.16 is the what i should see before clipping
Well if you know how to set the gains using a DMM, I guess Im just confused why you intially told us this \ . Have you verified your DMM with your ears? We are discussing distortion, and I just realized the only symptom described is your subs are getting hot. We cnnot assume there is a correlation, or even that your subs are abnormally hot.
the problem with using a DMM, is that it wont tell you if youre clipping, just tell you how many volts youre feeding your sub
and yes that Velleman scope works great
when you smell them there abnormally hot (burn smell), and no i always do my setups by ear, but since you so insisted that i knew nuthin i went out a did a dmm check to make sure my ears wasn't trippin, but anyway
coo i just ordered it, should be here by weds //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I didn't insist you 'knew nuthin'... I insisted your description of the situation implied you knew nothing. And I was correct. If you set them by ear, I still have to wonder why you told us \ . Its like complaining you got a speeding ticket, and when someone asks how fast you were going, you say "my speedo read \ ". But im not here to argue, it doesn't really matter either way to me. Im just explaining why I made the comment, because apparently I need to.
naw it wasn't a need to do anything, you didn't need to make that comment you made a choice to make that comment, just like you didn't need to come in this thread, you made a choice to come in this thread, since you felt tha so call "need" correct me, i just wanted to correct you on how you was using that word
Its amazing you know how to set a gain with a dmm, yet you described your gain setting as a relative position on the knob, absolutely worthless info. And its amazing you 'always do your setups by ear' when you just got done asking us if clipping is audible. Clearly you really know what you are talking about, huh? If you are gonna be a smart *** to people trying to help you, at least be smart. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Good luck with your issue.
and there goes one of the smartest and shapest guys on the forum!! most likey the only guy who would have been able to help out a bit more then normal ppl can lol!!
actually no-one really help with trying to figure out what the problems was, i asked was clipping audible was to double check myself, cause i was told it was to a certain extent and most of time people buy overrated amps so a dmm would be worthless, and what was worthless about my info, i said deck volume, bass settings, and to if anybody how has had the amp and same amp as me could pretty much have a visual of where the gain was set at, but once again really nobody really helped, if i could put up the responses to this thread side by side with the reponses i recieved on caco, you would see which forum was more helpful in trouble shooting my problem
but thanks you did provide some info but you didn't help me with my problem
i know my electrical isn't enough as of right now, cause 12.48 isn't a bad voltage drop but it's not a good one either, and if i take it to a shop here it would end up like this other guy i knew, he was running 7 amps total 3 ma audio hk 4000s and 4 amps for mids/highs, and they did 4 batts and one run of 1/0 gauge to the back and once they got to the back does dummies broke the wire down to 4 guage to wire all the batts together, now i def. no better than that, i'm actually redoing his electrical now, i'm waiting on a motor so we can do a dual alt setup for him, going with 8 batts for a samson 8k now
crownvic02
crownvic02
Orlando, Fl
mattxc
