lilpnoybreaker
hi,
for my next install, my plan is to try and keep my jump seats on my Land Rover Discovery and build the box under and around it. It ends up to be a U shaped with the 2 sides being the same size and the center being a wedge type box to fit along the back of the second row seat connecting the two. Each side box totals to be 1.62 cubes and the center totals to be 2.98 cubes.
________________________________
__| __________________ | __
__________| |___________|
this is kinda how it will turn out. there will be 1 sub in each side and 6 inverted against the wedge type box. the port will be ran off the middle about 3" tall. i was also curious if it would be a bad idea to have subs facing in different directions (they would be mounted where the arrows are pointing towards each other.)
the total is 6.22 external. also should i use 3/4 or can i go thinner?
thanks
andrew
thanks
andrew
