What grit?
negativezeroz
Nothing Is Promised
I started my first fiberglass enclosure yesterday. Already have parts that sag because I didnt get the mat tight enough. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif But Once I'm doe laying the several layers, what grit of sandpaper do I use to get it ready for paint? And what are the right ways to paint it? Like sand, primer, paint, clear, etc... Thanks.
80 grit on glass, bondo, 80 grit, primer, 200 grit, 400 grit, paint, 1000 grit wetsand, 1500 grit wetsand, clear (if using) 2000 grit wetsand
most of the times you need multiple coats of primer, paint, and clearcoat
40 to shape
80 to smooth
prime it.
220 wet
prime it
400 wet
40 grit is NOT a bad idea on a power sander my friend. yes 80 will knock down what 40 will..............and lose a lot of roughness in the process. im sure noone here can spread bondo perfectly. this is what 40 grit is for, you know where u spread to swipes beside each other, and have the ridge between the two, not to mention it makes your 80 last longer and work more efficient.
negativezeroz
Nothing Is Promised
negativezeroz
-salad fingers-
saywhat?
