type-x or w7
type x is not in the same league. get the w7 in a sealed box and get a jl 1000/1 amp with it. if your asking that question u should have some change in your pocket
i do agree to a point. as i stated earlier, if you have the room, you could get 2 type x's and a 2000w amp for about the same price and have better results than with 1 w7. 1 w7 would be nicer than 1 type x. 2 type x's would out perform 1 w7 and be about the same price, if not cheaper. 2 w7's would be like bangin' an expensive hooker. it'll be really good, but you'll pay for it.
the type x was designed for SQ. The w7 was designed for SQL. I like single sub setups better because the box won't take up as much space as two subs and there will be no phase issue and it will cost less. So get one ported w7 and jl 1000/1 amp and that should be enough to bump hard and sound good
If you want something with EXTREME low end extension, get the type-X. It's probably one of, if not the best sub on the market in its price range for sick low end.
sxkicker89
sxkicker89
delaware,dover
sxkicker89
