Type R runnin 1kw daily?
Yeah its a trunk.. seats in the back are removed tho, so Im sure I can get there somehow.. Right now I can blow out zippo's, but thats about it.
takes alot of work to do hair trick w/ a trunk car. also which type-r's do you have seeing you mentioned a pole vent in your other thread.
ill clarify my first post a lil, my 1 15 i ran off of 3111 actual rms watts, and the 2 12's are running off of anywhere from 3.5-4+kw actual rms power havent clamped it yet all i know is i smoked 2 50 amp fuses(so total of 100a) like nothing as soon as bass hit.
In theory 100 amperes worth of fusing would only be sufficient for just under 1.5kW.
(100a X 14.4vdc = 1440)
In theory 100 amperes worth of fusing would only be sufficient for just under 1.5kW.(100a X 14.4vdc = 1440)
tell that to a MECA competitor... lmao //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Last year I was runing 2700 watts on a 50 amp fuse for a burp //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
right now its unfused so dont comment on what you dont know....
also "in theory" the 3111 watts was on a 100a fuse so i guess "theories" arent always correct.
No, a large ported enclosure would yield less power handling.
Generally, a small sealed enclosure would be ideal for throwing a ton of power at a driver, but not always ideal for output purposes.
experience pwnz you //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Actually, he is right. Throw a 300 RMS driver into a 15 cube box with 1000 watts and watch it go up in flames.
A small ported/sealed enclosure technically yields more power handling
75MonteCarlo
pwned by the R
75MonteCarlo
Saskatchewan, Canada
jrpro130
vegang
vegang
