Two much head room ?
rp69
Hello gust wondering if 325rms two set of components is to much power . The components are focal 165krx2 which are 100w rms and are a 2ohm set up . The amp is a ppi power class 650.2 it does 325x2 at 2ohm. It's a very low distortion clean amp with good dampening factor.
i would be careful setting those up on 300w each rms, they may take it but you're going to need to watch your high pass filter and likely set it pretty high 120-150hz. if you hear any distortion turn it down until it goes away
I am still learning so if what I am saying sounds crazy is because herd the info from other people. Will it be OK for the crossover net and will the tweeters be able to handle it .will I have floor noise issues
To be helpful, not to be rude:
damp·ing
ˈdampiNG/Submit
noun
1. technical
a decrease in the amplitude of an oscillation as a result of energy being drained from the system to overcome frictional or other resistive forces.
damp·en
ˈdampən
verb
gerund or present participle: dampening
1.make slightly wet.
damp·ing
ˈdampiNG
noun
1. technical
damp·en
ˈdampən
verb
rp69
rp69
calgary alberta
n2audio
