two HDC12's dual 2 ohm northern arizona audioque
  • 2
Harleyfx69
audio n00b
414
arizona
audioque hdc 12 dual 2 ohm,
work perfectly, a little dusty from being in my truck, initially ran off 2 aq' 2200's linked, then sold one of the aq's, and ran both off 1 amp, which was plenty, amps were powered with a sufficient electrical system with no clipping or damage to subwoofers,
Come with the box you see, full 3/4 mdf construction with glue and nails, i dont recall the specs but it was built on the low side of the recomended specs off aq's website,
also have two that need to be reconed, one works fine when i took it out, but still seling it for cheap,
400 for the two fully functioning subs with box,
200 for the two that need to be reconed,
buy all of them for 500 ,
These are very heavy subwoofers and i dont even know how i would ship them, i would greatly prefer pickup within the northern arizona area, if you buy all of them im sure i can work something out for delivery,
also have an aq 2200 in another auction, i would combine everything for 800 and throw in some 0 gauge wire,
to the top,
make offers, these things are just taking up space in my garage, and i am even willing to work out delivery on them,
shipping is possible but i have no clue how i would do it .. and it would probably be expensive,
207
518
958
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
909
Harleyfx69
audio n00b
Harleyfx69
arizona
Harleyfx69
