MitchZ
I bought my friends broken Viper 2500D off him for 100$, because I figured it would be a cheap fix. And its my original Zx2500.
Here are each of the stories will pictures included....
Kicker Zx2500.1.....
I was running 2 Pioneer Premier subs (800 RMS each) @ 4 Ohms, I took the subs out for a few days just so I could clean up my car a bit, vacuum, etc. I left my amp plugged into everything. (Power/Ground/Remote/RCA's), but there was no output.
So it would just Idle with the green light on. Then on Friday, I'm driving around a corner and "POP" and it started smoking. I was like "Oh fkkkk....." and I turned my engine off immediately and I ripped off the deck faceplate. I unplugged the amp and looked inside... There are 3-4 noticeable burn marks, each are on different channels of the amp on the transistors.
Pictures:
http://img266.imageshack.us/img266/4711/dsc00201da3.jpg
http://img212.imageshack.us/img212/6806/dsc00202ex5.jpg
Viper 2500D.....
My friend was playing the amp on very low volume. (5/60) but he was running on stock electrical and his Solo X 10. Then his just blew up the same way mine did.
Neither of our amps turn on. There is this only noticeable burn mark.
Picture:
http://img212.imageshack.us/img212/9086/dsc00199fb9.jpg
I've talked to many people about transistors, fixing electronics in general.
A guy at my work (a computer tech) says transistors usually blow in pairs, and they cost 4-5$ a pop).
The guy at the electronics repair shop... (Who has the Viper, because all the transistors were pulled out by a car audio shop - who were idiots) explained to me about how "Either all the transistors are blown, or it could be just 1 or 2." (and they go for 4-5$ a pop) And the other channel should be fine.
Is there anyway to test transistors to see if they work with a DMM?
Should I try to fix it myself with the correct transistor? (I know how to solder)
Could there be another problem other than these transistors?
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Any help / advice / explainations is very much appreciated. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Pictures:
Viper 2500D.....
Picture:
