two 18's in an ext cab truck.
Justin braaapp
Im thinking of upgrading from my current one 15 setup and was thinking about doing two 18's until I was told that two 18's would be too big for my extended cab Silverado 1500 truck. He said that the problem wouldn't be fitting two 18's in my truck but that the subs wouldn't have enough room to create sound waves and sound proper and it would be more of a one note hitter build. He said in my truck I would get more out of a smaller setup with multiple subs like 4 12's. Has anybody heard of this before? I was really set on two 18 inch hdc3's until I heard that so if anybody has some insight I would appreciate it.
air space is air space, as long as your not trying to do a 4th or 6th bandpass which I have seen a few that work and a few that dont, standard box or wall will work fine. If it was a shop that told you that find a new one, and if a friend, well get a new one lol
This truck does a 159 at the head rest, 2 18's below window line.
That thing looks nasty! I should have specified though this is a straight daily ground pounder build, I don't care about numbers I just wanna get loud to the ear and sound good while doing it. Knowing that you still think two 18's would sound good in my little cab?
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
972
Justin braaapp
Justin braaapp
Torrance CA
Justin braaapp
