tweeter placement.
andrewibk
in my 07 civic, i have a tweeter spot with grille and everything from the factory. wierd, honda might as well put in factory tweets if they have a mounting spot and a grille and everything. anyways though, it is right under my windshield, would it be worth it to mount it there ? dont really wanna drill any holes =/
There is a spot like that in my 1999 GMC Jimmy... I asked this question to someone else before and they said it really depends on whether or not your tweeters work well on or off axis. If they do work well off axis, then you will need to experiment with the location of the tweeters (you can do this by putting velcro on the back of them so they will stay and seeing where you like them best at)... after that, just mount them.
I'm running my RSD tweeters in the sails right now. Sounds great. I originally tried in the stock location (in the doors) but wasn't happy at all with the rainbow effect. I was used to the sails from my Infinity tweets so it may have been just something I wasn't comfortable with either.
But with the tweeters in the sails, using my old mounts to fab up some new ones, aimed at the driver they sound great. Sound stage is moved up nicely and no more rainbow effect. I used velcro and experimented with different positions as well. I'd suggest that, then mount them where you think they sound best.
It's were the sound seems to be coming from in front of you, but tapers off around the edges of the car. To me, with the tweets in the doors, my vocals and mainline frequencies sounded good (right in the middle, top of the dash). However, as the frequencies tapered off, they would seem to "fall" to the floor/kick areas. Made the sound seem like, well, a rainbow. You understand now?
as always.. it's whatever you think sounds best. so try them in different locations until you're satisfied(with the velcro, so you don't have to drill holes all over your car), and then mount them. after a week or so you may want to move them again.
what infinity's did you have?
5000cs 5.25" comps. They sounded good, but no where near the RSD's. Granted I made some custom baffles to fit the 6.5" RSD 65cs in, but the difference is large. The RSD comps have WAY more midbass than the Infinitys ever could dream of.
I actually have my 5000cs set on Ebay right now. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
In all honesty, Infinity has great midrange and I've always liked their tweeters (some people don't like the brightness). However, I've always felt that most Infinity drivers lacked midbass. That's one area where these RSD's really blow away any Infinity driver I've ever heard or used.
In fact, I dare say I've never heard a driver quite like these RSD's. Granted I've not heard any really high end stuff, but the more I have this comp set, the more I love it. The drivers are really starting to break in and they get better all the time. Definitely good comps.
I have 07 civic as well i mounted them a lil NW of the 6.5 door speaker about 4 in. from it. the only thing i didnt take note of is the door handle it actually interferes with my direct line of hearing to the tweeter so id keep it above if u can, honestly i should of put em in the dash to be ear level. now i havent put any components in the rear so i do still hear the rear deck moreso than the front so i had to fade +8 to the front to compensate till i do upgrade, running a pdx 4.100 to power my Focal components.
I know you don't want to drill any holes, but having the tweeters there has never really worked well (sisters camry was an example)...
If I were you, once you get the comps, install the woofers in the stock location (or kicks if you are going that route) and play with multiple locations for the tweeter(double sided tape FTW!). Get a nice long slack of wire coming from the crossover and try: Kick panels, A-pillars (about 3 inches above the highest point on the dash, firing across the dash towards each other), and as a last resort the stock locations...
A-pillars works best a good 80-90% of the time. Be sure to play with phase (tweeters especially)
andrewibk
andrewibk
Orange County
Fast1one
