keep_hope_alive
Premium Member
Acoustics Engineer
don't forget that you localize sound based in time arrival (ITD) for frequencies below ~3kHz and you localize sound based on intensity (IID) above ~3kHz.
Crossover point and slope should be taken into account here. A 3kHz 12dB/oct slope does not get you above the IID point. a 4.5kHz 12dB/oct slope is a better point. The reason should be obvious; the speaker will be audible below the crossover point. When a source is 10dB down relative to other sources, it no longer adds to the cumulative sound pressure level. In other words: if you have two sources producing the same frequency and one is 10dB lower than the other, you only measure one source.
This is why people will say that T/A on tweeters isn't necessary - just proper aiming. What they should clarify is that the statement is only true for crossover points/slopes above a certain frequency. most component sets use a crossover point below 4kHz, so when using passives, you are best to just T/A the whole set - locate your tweeters at a distance from the nearest headrest that is equal to the door woofer, and aim them off-axis relative to the nearest seating position. naturally, this is a general statement and each vehicle should be tested.
lastly, T/A is not a requirement for a good soundstage. it is a bandaid for poor placement/installation. sadly, our cars are poor environments for speaker placement. we do our best with placement/install, then use tools are our disposal to fix what we can.
