etznova
ok so i just hooked my amps back up and i have a nasty turn off pop, now i had it before but not as bad
so here is my wireing rundown
my remote goes to a standard 30 amp relay and then branches out from there to my Battery isolator and to my three amps a memphis 3004 and 2 vfl 150.1 now i only get the pop through the sub amps
another question is i have a newer pioneer DEH-6800mp now i have get a lot of engine noise out of it, i have heard that they are natorois for that how can i fix that send it out or ground the rca or ground isolator
another thing with the deck is i have noticed is that the remote kicks off if you turn the volume to zero and if turns off and on if you change sources (from xm to tuner to cd and if you eject a cd it kicks off is this normal never seen a deck do that before
sorry for the long post i hope it makes sense
