Example being this, a little drastic, but still holds truth to what I said.
T3 45trim @ 9psi
Max flow is around 15lb/min
T76 @ 9PSI
Max flow is around ~70lb.min.
BIGGG ol' difference.
I run 30psi on stock internals... Its the flow that matters, not the psi.9psi is not that much. SRT-4 come from the factory pushing 13psi...
If the owner has the gate at 9psi, then he should be slapped. I'd go check it myself and move the puck to make sure it wasn't a retarded owners fault. Then check the vaccum lines to the boost controller, and to the turbo, making sure the boost controller is properly setup. Then check the puck placement on the DP.Then the turbo he put on probably is internally gated at 9psi. But there are certain things you need to look into. You may not want to up the boost. A PR of 1.61 may be the in peak efficiency island with the turbo selected, as well as providing power is the desired band. Upping the boost may cause problems with flow. Try to find out what turbo it is and we can get you some maps and flow numbers.
And you need to knwoo what you're flowing before you go and buy an aftermarket IC,it would **** to end up losing 4PSI because you chose the wrong IC when you didn't know your numbers, ya know.
psi is psi. The guy was asking around how much he thought the engine took stock and we were replying with how much some stock vehicles were running so he could get an idea. And obviously we were close in are assumptions since a stock GN as stated above boosts at 15psi.
Are you saying that regardless of the turbo, he should not have it gated at 9psi? Or the stock turbo should not be at 9psi.If the owner has the gate at 9psi, then he should be slapped. I'd go check it myself and move the puck to make sure it wasn't a retarded owners fault. Then check the vaccum lines to the boost controller, and to the turbo, making sure the boost controller is properly setup. Then check the puck placement on the DP.
don't the wrx evo srt-4 all come with around 15psi stock? or closer to 1 bar
Most GN's are cold air. Duttweiller started with us, and then moved to LS1's..most people don't realize that.Boost's just an easier way to read airflow. Someone said boost is boost, which is 1/2 right. 28psi is twice as much flow as 14 psi ON THE SAME ENGINE. 14 psi on a grand national might be 2x as much flow as 14psi on an srt-4. And 14 psi is out of a t4 is the same as 14 psi out of a gt28r but the 14psi out of the t4 might be cooler, but later in the power curve. Comparing different cars, or even the same car with different turbos is difficult. The only way to figure out what's going on with your car is to actually have it looked at.
Spearco intercoolers are great quality, and one with pre-welded endtanks can be had on ebay for under $300. Aren't there people who run their nationals hot, as well? Never understood oldschool tuning.
Anyways, i'd do a compression and leakdown test before anything, just to make sure the headgasket and rings are in good shape before you start adding boost. Shouldn't cost much at a shop, an hour of labor tops, or free if you can find someone with the equipment.
Good luck!
