Tsunami question
hmm thats still coo..1800x1 ..900x2
so i'll get 900watts to each sub.. sounds good..but is there another amp that will give maybe 1000 to each sub.. for about 400 bux...
p.s. i got dual 2ohm subs so i can only do .5,2, and 8ohms...
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif but y would i ever want to do 8ohms //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
so is the tsunami my best bet.. cuz i'm kinda willing to throw out some more cash..
i mean i might not notice the diffrnece but i'm shure the mic wil :p
but what do you suggest for an amp
alrighty i thik i found one //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
check it out
http://www.outerlimitsaudio.com/product.cfm?ProductID=4747
now that will be 1800watts to each sub :p
now i gotta go find a job and make some money //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
i now i got 300somethin from sellin my amp and my old speakers
so now i gotta come up wt 200 somethin dollas....I wonder if i can find it for cheaper???
hey, there's a second hand orion HCCA 275G4 (stable to half ohm and under rated like a mofo) amp for sale, mint condition with original box and documentation. PM me if anyone is interested. ****, it looks good.
ok i've read some reviews people have said 1000@1ohm
2100max
but i think it's like 1800..i could be wrong i got this lil eqaution that usually works...multiply the fuse rating, by how many there are and then multipy by 10 and since this amp takes 6 30a fuses 6x30=180x10=1800
but i just found this fact sheet on it
POWER OUTPUT 2 x 75 @ 4 Ohm 2 x 150 @ 2 Ohm 2 x 300 @ 1 Ohm 2 x 600 @ .5 Ohm 1 x 300 @ 4 Ohm 1 x 600 @ 2 Ohm 1 x 1200 @ 1 Ohm SINGNAL PROCESSING Varible Low-pass 45Hz to 5kHz, variable high-pass with INTELLi Q 10Hz to 10kHz, 10dB of boost with INTELLi Q, remote gain capable, selectable AUX out FUSE SIZE (6) 30 ATC DINEMSIONS 25" x 10.25" x 2.25" (635mm x 260mm x 57mm)
so thats only 600 to each sub, which is what i have now, but how much are we talkin here
Just an FYI, The Tsunami DB1800 is 1800x1, or 900x2. Its This::
1800 WATT CLASS T DIGITAL POWER AMPLIFIER
Advanced Tri-Path High Efficiency Digital Design
1x 900 WRMS @ 4 Ohm Mono .1% THD
1 x 1800 WRMS @ 2 Ohms Mono .5% THD
High Thermal Efficiency Heat Sink Design
Distinctive Backlit Logo Badge
Signal to Noise Ratio -90dB
Variable Input Sensitivity 250mV to 6V
Variable Low Pass Filter 50-250 Hz
Variable Sub-Sonic Filter 15-50 Hz
Variable Phase Control 0-180 Deg.
Remote Gain Control
Current and Thermal Protection
Why dont you just get another JBL 1200.1 or whatever they are. That would be your best best. Wire one to each sub?
yea um thats pretty much the same thing 1800x1 would be reduced to 900x2
well my amp is acting up.. i dont know if it's my car or the amp i'ma hook it up in my buddies car and if it works syanora for it...
djjdnap
FreakyFreaks ofall Freaks
djjdnap
indy-nap-lis
djjdnap
