All attenuation means is lessening. A resistor works by opposing current, which is caused by a voltage drop between the ends of the resistor. Naturally, by rearranging ohms law, V=IR and P=IV can be re written into P=V^2/R. When you increase the resistance, it's easy to see that you get less power to the speaker, and therefore less output. This is helpful in speaker building when using bright or very efficient tweeters where you want to match the output of the tweeter to the midrange and woofer. By attenuating, or padding, you can get a far more seamless response.
An L-pad is a type of padding network. It actually stands for loss-pad which is how it works. It's used to effectively change the resistance of the speaker it's connected to which lessens its output in the frequency ranges where it matters (higher frequencies most often). They are connected to the crossover, one in parallel with the high pass circuit, and one in series with the low pass circuit. In essence, an l-pad cuts down on the tweeter's output which makes it flow better with the rest of the speaker.
A zobel network is a bit beyond my knowledge to explain, but I'll try. Basically, a zobel matches the speaker's impedance to make it easier to have a consistent ohm load sent to the amplifier. Note that zobels are NOT mainly audio circuits, but they are still used to attenuate different filters in crossovers. The way they work is by cutting a speaker's inductance at certain frequencies. Inductance in its most basic form is the resistance to a change in current.
The way it was explained to me is like this. Take a dam with water behind it and a water wheel in front of it of significant mass. The water starts flowing from the dam, and at first, the water is backed up while enough force builds to turn the wheel. After that, the speed evens out. When you go to close the dam, the same thing happens in reverse. That water wheel is resisting the change in current and as such, is storing the energy in the form of the water wheel turning. The inductor does the same by storing the circuit's current as an electromagnetic field that builds as long as the current is kept the same. At higher frequencies, more of that water can flow (thus more output). You then employ the zobel as a heavier water wheel to counter act that.
I know it's a bit daunting and I know it's confusing because I don't even understnad this shit well enough myself, so if anyone can clear that up, I'd appreciate it.
cliffs: You need to make the tweeter less loud
