Trying to add a sub to my car- Help Needed!
aheezy6
I have a 2004 Touareg with a regular radio with a cd player but I have a premium audio system with an internal subwoofer and amp. I want to add an aftermarket amp and sub in addition to the premium system that I have. Is there anyway that I can keep the factory amp running for all the speakers and the factory sub while having the aftermarket amp running for my additional sub? Any help is appreciated, Thank You.
yep can do. You may require an loc so you can adjust the input level going to the aftermarket amp. If you get the right amp then you could wire it high level and use the signal sense to turn on the amp. I know off the top of my head that some fosgate, alpine, and sony amps will do this. do some research on what kind of gear you are thinking about putting in there. Things to consider, how much room you want to consume, how much output you really want, and how much you want to spend. if you want to go big then you will need to upgrade the electrical as well.
What is a loc? and the amp I have is the audiopipe aspm 1500
bro just throw a sub and amp in the back... that simple if your not upgrading the interior spks.... if you want it to go on/off hook up a taco switch... I got factory amp and spks and sub in my ride and my sig....
aheezy6
aheezy6
Tampa, FL
CrossoverOre
michigan born
    May 14, 2026
michigan born
    May 14, 2026
