Trunk Rattles -Solution?
You pay for what you get bud, dynamat isnt really all that pricey when you think about it. Took 110% of the ghetto rattle out of my car and more. Trunk kit does a hefty job, easy to install too.
Dynamat is horribly overpriced. Check out the products squeak listed.
Second Skin and Ant has some kicka*s deals happenin right now
Peel and seel will work if your car doesn't get hotter than about 100 degrees on the inside. I use secondskin. It can handle 480degrees or something like that. It works rather well for eliminating rattles. B-Quiet is good from what I hear too!
I use peel and seal and my car is regularly exposed to 100+ degree heat, reaching up to 140 degrees inside. That stuff does not budge or curl up.
Engine compartment (firewall exterior, underside of hood, etc) would be a different deal though, definitely use SS there!!!
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
815
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
BigSteezie
BigSteezie
Nob City,Ind
Zerstorer
