TRULY low bass songs. I'm talkin 20-no more than 35 hz.
Juice Box - Gorilla Zoe
It's been mentioned plenty of times before in the bass track thread, it peaks at 36Hz -2db according to Audacity. (not quite low 30Hz range, but it's decently low)
It's a lot quieter than -2dB. It's around -6 or -8
I need someone to send me some decaf stuff. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
you got munniez?? i got zip 1-25
//content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gif
I just double checked it and that's what my copy of the songs registers at in audacity. I obtained the song from a link in a thread somewhere around here, so maybe my version is a bit boosted.
36Hz isn't too low, but the OP was asking for up to 35Hz, and I don't see 36Hz as being too far away from his criteria... It's lower than most rap out there.
If you got that version from me then it should be at -3dB. Set your frequency analyzer's function to Blackman-Harris window. It's the most accurate one IMO.
Yeah, and the OP made this topic over 2 years ago.
the human ear can not hear under 20hz so if u hear anything under that its just harmonics and or be that distortion. No one is listening to 12hz pure sine wave complete failure on here with that 12hz bs
you could certainly feel it but no way in hell could you hear it. Some people can hear under 20hz but only a few hz lower.
449
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
620
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
bullet4mv92
bullet4mv92
Fort Worth, TX
mcowens
    May 20, 2024
    May 20, 2024
