True 4ga, or bullshit?
PollyCranopolis
Bees!
Saw an ad on ebay for 25 4ga power wire for $15, so i was like hell yeah! (wire in my area is like $3.50 a foot). Heres what I got. The wire on the left is my older, original 4ga power wire, which is labeled:
"600 Series, Gold Level, Hi Current, 3Inner Flow, 4ga, 25mm/2 Power Flow"
The new wire on the right is labeled:
"Pyramid High Strand, 4ga Pro Power Cable"
As you can see, it looks as if the new wire on the right has significantly fewer strands, and a much thicker coating. I'm wondering if this new wire is bullshit, or if it is a case of manufacturing less wire, with higher copper content to compensate for it's smaller size. Any suggestions?
AWG is cross section. All 4ga should be the same size. Looks like you got jipped. If they didnt say AWG that is where they got you. When I was at Shawn Flemming's shop he has some '1/0' that was no bigger than my 4ga laying around. The OD of the caseing was as big as Kicker Hyperflex but the wire was small.
All the cheap wiring is like that I ordered a 2awg wire kit for amp install when I ran short I got more 2awg at my local sound shop and the online stuff was prob 2/3 the size of the real stuff.... Now when I order online Ill order 2 awg if i rlly need 4 and 4 if i rlly need 8 ect. ect....
I found the same thing when ordering some 0 awg wire. I went cheap first then went more expensive. Here is what I got. Of course the expensive 0 awg is o the left, the cheap is on the right. And yes both were supposed to be 0 awg.
PollyCranopolis
Bees!
PollyCranopolis
Frostburg, MD
CBFryman2
