Trouble with system, Any idea?
2Dcore
F*It
722
PA.
K, I put my system together and it sounded awesome for what it is 4 10" alpine r's ran by Kicker kx2500.1 Ran up to 2ohm's sounded good for a month than i noticed it wasn't hitting as hard and kind of muffled almost distorted sounding but still hit somewhat than out of the blue it will started hitting again almost sounds like what it does when out of phase but it's not i checked everything but it did seem to start when i put 2 new amps in for mids and highs. Any thoughts on what could be going on? Bad ground do this? Thank you
no voltage drop it doesn't do it all the time it slams than maybe a day or so it might do it again i keep a meter on it to see volts 13.6-12.4 est.
Plenty of juice for 2500rms 2 kinetic 2400's big 3 alt is stock but no bad drop. it doesn't drop out when it's working correctly it will hit for days but when it goes it will last for days.
Seems kind of stupid to prevent helping others with advice on equipment from Amazon, doubt that Amazon is preventing this either. Pain in the arse!
14
900
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
970
Try tracking down your leak. Check your trunk, and around your antenna wire.
Back in the late 90’s, I took my S-10 to Pigeon Forge Tn for the Mini Trucking nationals. The cops there were the worst that I ever seen. They...
I'm not a big fan of Brand X personally. My car idles at 500rpm and my Autotech didn't turn on until 650. I sent it back and he redid it to turn...
841
2Dcore
F*It
2Dcore
PA.
2Dcore
    May 12, 2024
Brendon Jenness
    May 11, 2024
