tricks for retrieving bolt from engine compartment?
have u jacked it up and looked around from underneath? ive been known to find a bolt or two from just looking from a differnt point of view
im still gonna say try a magnet on a stick.. just poke around in every possible nook and cranny, and then get under the car and do the same think... on a stick will keep it from getting stuck to everything like it will on a strang
id have to say the jacking it up my help.
Just keep looking until you find it.. use a flashlight and look in every possible spot, also find a friend or something to have another set of eyes, as you might be missing it.. otherwise like they said before, use a hose maybe to spray the hell out of everything, or an air compressor with a air gun to push a lot of air through there..
Andrew
Plasma cutter will do it
i was just gonna say that
I've tried that many times with the string magnet since i seen the bolt fall. But it just stopped right there still in sight and didn't bounce farther down like the bolt. I had to drive to work early this morning so it could be all gone by now. I guess ill just use one.
i did that during my install......i couldn't find it and ended up running to wal-mart and buying extra terminals. I heard a big metallic thunk under my car as i pulled into work the next day, and when i left my missing battery terminal was laying in the parking lot. most likely you would have heard the terminal hit something if you lost it while driving.
hondarider
hondarider
glidden, IA
mapolley07
NorthFramingham
    Jun 30, 2026
