treo vs sundown
i'd say go for whatever is cheaper. they are really similar amps in term of output and build quality. i've been running my treo ssx750.1 at .666 ohms daily and it does fine. i might be selling it soon too if i can find a 1500
just take a peek at reviews about Treo 1500.1's.
they do ALL of 3000 rms @ 1 ohm, 1500+ @ 2 ohm.
but the sundown amp is nice as hell too. 1500's are SOLID as bricks.
the amp is 1 ohm stable, i had the 1500ssx and it was a stout amp only problem was that they are current hogs
takes power to make power.
We can fix the Treo 1500's, never worked on the smaller treos... The SAZ-1500D is good at 1 ohm, 12-16V. output will range from 1400-2000 at those voltages. I think the Treo 1500's are pretty beastly amps, but they tend to break legs off the FETs from vibration, causing massive destruction of the mosfets... Those god-****ed spring clips... cheap bastards use spring clips.. Sundown is "screw and alluminum block" all the way, no spring clip shit.
mojobass
mojobass
Ohio
cleansoundzz
