Treo subs
I haven't heard a TSX...but, I like a sub that can go low and still hold it's own SQ wise. //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
tsx sounds leagues better than the ssi, and still can go low. the tsx is a lot more energetic. i went from two ssi 10"s to two tsi 10"s and was happier with the SQ, then i went to a single tsx 10" ported, and now onto a pair of dd's. its a never ending cycle with me.
I hear you...I went from the SSi's to 10W7's now to 12" MAGs. My biggest problem is I perfer the sound of a 12" over a 10". Call me crazy but I do.
Like I said...call me crazy. Everyone has his own ear. This isn't a topic I debate.
sometimes a 10 might not sound as good as a 10" will because you push it harder to get more output and it distorts or just doesnt go as low, which you might not have to do with a larger woofer. that is the main thing i see when people are like my 10"s dont sound as good as my 12"s or something like that.
Back to the post and the answer to the thread starters question. The answer to your question of "why does it sound like crap and does not get off" is NOT because it's a prefab box. I prefab boxes that are common sales for me, such as extended cab pickups. The problem is that your particular "prefab" is of small volume and is sealed. If a pair of 10's won't get off in an extended cab pickup, one the box is not vented and/or the enclosure is roach d!ck tiny! You don't get big sound from a small sealed enclosure, you are limited to the displacement of the cone x it's stroke capability. That's the least efficient thing I can think of other than just sitting a sub bare azz nekkit in the back seat and expecting it to get loud. The fastest, least expensive cure is to take one of your subs out, knock the center divider out of the box, replace that with a center brace that allows plenty of air to move through and cap the hole of the removed subwoofer. Next is to vent that cap to the tune of 16 square inches of port area per NET cubic foot of enclosure volume. Make that port 16" long and you'll get louder on less power, guaranteed. If you want to stop playing around, lift the rear seat 3" with 2x3" square steel tubing and some high grade bolts/nuts and washers. Then you have room for about 2.5^ft of net volume under the seat after subs and port. Built that box with a center vent that is rear firing and is about 3" from the back wall of the cabin. Now your truck will get stupid. The vent needs to be the same formula... 16 square inches of port area per NET cubic foot of enclosure volume x 16" in length. You will be happier either way you go, just way more so with the latter option. Have fun with it and get back with us when you opt for a louder solution.
blah blah blah, 99% of the prefab boxes dont sound good at all because they lack R&D, or they are a simple design that takes less time and effort to build.
budahbuddy803
budahbuddy803
Aiken, SC
bri487
Mike Mccabe
