Total noob
Cadillac_02
First box build any advice as far as we're to start I want to build to fit the available space in my trunk car is a 02 Cadillac deville the box I am wanting to build is for a 15 in woofer preferably with a port. 3'4 in mdf will be used also would like speaker to be flush mounted with fiber glass face wich i will spray to match vehicle exterior any tips or advice would be helpful before I start building thanx
If you have never done any designs or building before then I suggest searching the forum and internet to better understand the design process and build process.
Measure your car 5 or 6 times to make sure you have the dimensions right. Also make sure the enclosure will slide in the trunk opening. Build a cardboard version of the box if you have to and slide it in/out to make sure it works.
Measure atleast 4 times before you cut. Even when you think you got it, measure again. Other than that, it's all a learning process. Fiberglass can be tricky if you aren't familiar with it. So I will reiterate what Pro Rabbit said. Read your literature, and try building a cardboard box first. Practice on cheap plywood before doing anything new to your MDF. I wasted alot of money when I started. Good luck man! Post pics!
Cadillac_02
Cadillac_02
Harlingen Tx
Cadillac_02
