top post terminal?
negolien
Hey All,
Adding a 2nd battery could anyone recommend an inexpensive top post + terminal? Going to have a 0 gauge from the front battery and a 0 gauge to a disto block. Will need one for a negative also. Should I be looking for one with spots for a few rings like the knukonceptz negative? So I can use it for a ground for my two amps also?
Orileys Super Start AGM batts with Dual post what Ive been using for last couple years,and a good warranty.Great batts man.No need to run - all way back to the 2nddary batt.Ground it in the rear.Power wire from under hood to rear batt to distro what I do.I run same size wire to rear frame back up to a batt and then to a solid distro block to distribute from there to amps and ect.Be sure to get your Big 3 done under the hood. Google it/read up on it
Let me rephrase that. I have a 2nd battery and I' am looking for advice on how to add the + from the front battery and the o gauge power to my distro. Could someone recommend a good + terminal. I was thinking maybe one of these items below. Can you use the out as an in also? If not can you give me an Example of what to use.
Stinger SHT303 HPM Series Battery Terminal with Two 1/0 or 4ga
As for the Negative nm pretty simple I should use ring terminals and go to the negative on my 2nd battery for all of my amps and ground that to the frame lol guess I don't need help with that part.
SAE Battery terminals like these ? Hit @nrg up he can get you whatever you need .
Meh I' am only going to have two cables for the + and 3 for the - no need for a 6 lug. Might think about it if I can't find something I like. I did end up finding a 0 guage distro with a 0 and a 4 out finally though stupid stingers specs were wrong in a lot of the ads for the Stinger 823.
negolien
negolien
Sacramento,CA
negolien
