too much power
bridge the first two channels for the comps and using the remaining two for your 6x9's. it should help with your power issue, the RSD's are 60rms, the amp does 150 @ 4ohm, so it would technically lower the power rating (just a guess)
what? Than he'll be running his front speakers in a mono setup? WTF would he wanna do that for?
That amp would work, but if u just use 2 channels for the 2 components u'd be under powering them, should still get pretty loud but under powered. But that way u'll still have 2 channels for 6x9's in the back.
Or you can bridge the first 2 channels together for 1 component set, than bridge the 3rd and 4th channels for the 2nd set. But that way u'd have to lower ur gains, and technically u'll be paying for more power than you need. (the 2nd way u wont be able to run the 6x9's for the back)
doyoshuffle5
doyoshuffle5
lowell, in
doyoshuffle5
