Today's Install
Mickey B here is a post from stratusrt01 on the t-line box. I didnt build this box just to let you guys know as it seems some of you may think.
heres the formula, its simple, you would just need a pen , paper, and calculator. Quarter wave is all based on speed of sound, and length of the sound wave.
Sound travels at 1130ft / sec
to calculate length of Freq Devide 1130 / (freq) say 30hz
1130/ 30 = 37.66 ft long Full wave length But we need to devide this by 4- for 1/4 wave wich equals= 9.41ft long
Pretty long huh? And the worst part is, to have a true T-line, you need to keep the port/tunnel/line - a Line, that equals Cone area, or pretty close to it. If you have a 10" The average SD/Cone area is about 50-60sq inches (to find SD in inches, you measure the cone, by useing a tape measure, and measure from middle of surround, to middle of surround on opposite side) 10" is usually close to 9"- 8.5"-9". This is where Pie comes in 9"/2 = 4.5-------- 4.5"x 4.5"x 3.14" = 63.58sq"
That is your Port AREA ( usually round this number Down- say 60sq")
So, a Tline for a 10" with a Fs of 30hz, and a cone area of About 60sq inches, will be about 9.25ft-9.5ft long (rounded) Its okay to be a little off, because this is car audio tlines, the cars accoustics will not notice it, because of cabin gain. But, when building a t-line for a sub based on Fs, you need to keep in mind the speakers Qts, and Qms, they should be low for SQ, Qts of .40 and lower, and Qms of 7 and lower will work great. Qts is speakers total quality in Ratio to its electrical, and mechanical characteristics, Qms is the Mechanical ratio.
**** thats simple. Thanks for the quote bub, Ill save that one //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i dont have the specs as far as the box size i had them saved on a PM someone sent me about the same box but i have since then cleared my inbox. as DB to measure it up real quick for you!
No numbers yet because I traded a pair of SSD's for it the next morning and it is sitting in my jeep being ran @ 1000w until my other HDC3 15" gets here and my new amp. I'll be sure to get #'s and vids once I get it all setup in the Jeep.
DB_DRAG_SPL
Stupidity is Contagious
DB_DRAG_SPL
WV
DB_DRAG_SPL
