To Port, Or Not To Port
  • 4
MrFriskles
THE BOX IS A SEALED BOX
Hey guys, got 2 tens in a box going into this space between the bar and whats left of back seats.
Essentially this area here
Those two things on top are holes that used to be the old surround speakers, but they now go through to the trunk. They are basically just above where the box will go.
Question is this:
Is there any advantage to leaving the ports open to the trunk? more energy from the sub reaching the cockpit or something?
Or would it be better to just plug the holes up with some metal and put some damper on it to isolate the trunk better?
PS trunk is not going to be sound dampened beyond what was in there from the factory
I believe you would gain more if you port to the back instead of into the cabin.
This is only true if the box is small enough to not take up so much of the trunk that it suffocates the sub. If you are running something like a 15 and it fills up pretty much your whole trunk, it will be louder to turn the box around and fire into the cabin
The box is currently firing into the cabin. I think im probably going to fill the holes and just isolate the rear from the cockpit just for noise reasons, I was just curious if I would lose any "umph"
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
703
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
876
850
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
MrFriskles
MrFriskles
San Diego, CA
nauc
    May 18, 2024
    May 18, 2024
