TheSpeakerMan
Knockin Pics Of da Wall
If i have a 750rms sub (06 12" L7) and im giving it 2400rms from my amp will it blow my sub.
i would overpower any day over underpowering, but not by that much.
if you really have the ask this, then you will probably blow the sub.If i have a 750rms sub (06 12" L7) and im giving it 2400rms from my amp will it blow my sub.
Why the hell would you overpower instead of underpower it?i would overpower any day over underpowering, but not by that much.
If you're looking for a garbage amp then it probably won't do 1000-1500 watts too. You get what you pay for.
i think he meant under rms which from what ive heard will eventually mess up the sub.Why the hell would you overpower instead of underpower it?
The problem is, generally when a driver is underpowered, the user tends to push and push, and ends up clipping the signal to a point where the underpowered driver fails. If it is overpowered, the user does nto push as hard to get the desired affect.That is true, but it is the clipped signal that blew it not the fact you are underpowering it. If you threw a 1500 clipped signal at it it would blow just as well. And if you threw 750rms clean to it it wouldn't.
The clipped signal made it exceed it thermal limits. The only way to blow a sub is exceeding thermal or mechanical limits. Even sending 1500 clean watts to a 1000 watt sub can blow it if that power makes it go past the mechanical limits of the subwoofer.
