To divide or not to divide??? That is the Question
brs954
Need MORE power!!!!!
91
NY
Hey all...
Got a little question for you... I have a 3 cu.ft. box that my two MA Audio MA120xe's are in. Right now i built it so that it is not divided and I was wondering if I divide it if it would make a difference???
Please leave your input... need all the help that I can get
Thanks
BS
Would i get better sound quality out of the subs????
Right now they hit nice and low... but... they can have a tendency to kinda distort.
Would dividing help this????
Yes dividing would help. If you were going to use a common chamber i would build the total volume right at MFG rec's or slightly less than which would lessen or eliminate the distortion you said you are experiencing, unless it is from a clipped9distorted signal from your deck or amp). It also would reduce your low end. If you were to go ported you can go larger in the common chamber. That will give you back your low end and end up louder than it was..The down side is playing freq's lower than the tuneing freq will may also cause distortion from lack of control. That is where subsonic filters come in.
Mike
The MFG spec for the subs is 1.25 cu ft per sub max. I have it at 1.5 per... This is prob where I am getting the distortion...
the smaller the sealed box , the louder u go---> unlike PORTED //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
brs954
brs954
NY
BASS OUTLAW
