tips for not blowing new subs
CCCCavy.
CCCCavy
49
Ga
like the title says... just got two RD Sonances installed with a 1000.1RD amp running at 1 ohm and 35 hz. everything sounds good an clean... i just want to know if you guys have any tips or suggestions on how not to blow new subs... im been running the bass knob at about 1/4 for 2 days and everything seems fine... im afraid to turn it up anymore because i dont want them to blow //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Some will tell you to break them in i personally didnt with my btl but it is still stiff so but the way i have heard you break them in is play like at 5htz tone at low volume ovenight that should do it
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
dont send a clipped signal them or bottom them out you should be good
how will i know? will it sound bad? they sound fine right now, not distorted or anything... im prob. just bieng overcautious
Yea don't send a clipping signal.
Make sure your not hearing voices out of your woofers.
Bass knobs do cause distortion if not used properly.
Make sure your your voice coil isn't hitting your magnent.
They usually take 100hours of playing time.
But each woofer is different.
I did used to own 2 15 btls and I played them fully tilt and after a month were still kind of stiff.
i think all these post were stupid as hell.
there is a tutorial on how to set you gain for your subs
this means you will not be clipping the amp. a clipped signal will blow your subs faster then over powering them. you dont really need to break them in, just listen for odd noises or if it starts to stink.
if it does back down on the volume, you should also get a volt meter, they are very handy. if you see your voltage dropping into the low 11's turn it down.
to "break them in" just play them and dont do something stupid like play them all out with your car off.
My 2 15" L7s havent broken in yet and its been about 7 months,but I also only get about 1 hour of playtime a week IF that sometimes depending upon if I feel like driving my truck since its not a daily.
CCCCavy.
CCCCavy
CCCCavy.
Ga
slapperz
