thump when changing station
monkeyman
hello guys i was wondering if you can help me with a problem i am encountering with my sound setup ...everytime i change the station on my radio the bass will thump real loud or when i change from FM to CD it will thump it does the same sound when i shut off the ignition switch on the car big thumb!
when i had the "thump" problem on my old pioneer 6800mp it happend with the radio and between tracks on cds and ****.... it ended up being a grounding issue, so u might try to find that tutorial about how to ground ure rcas. cuz im betting that is more than likley the problem.... just my 2 cents
its a pioneer DEH-P3900MP , dont know what year it came out in but as i was saying i tried grounding the RCA's on the stereos chasis and the fuse on my amp would blow ......is that fishy or what
for some reason I'm thinking its an rca out in your stereo. When a rca goes out, and you have subs it tends to make this thumping noise.
the newer pioneers have this problem if you don't ground them correctly. I have/had the same problem. I grounded the RCA's off the chassis. Problem went away.
PS i got the loud pop when i changed stations, skipped tracks and turned the volume all the way down.
This could be due to a voltage drop. There's no constant voltage going into the head units. It's always changing. At which point this could be...
Simply put its an oldschool simple way of keeping the midbass in phase with each other when they are firing at each other in the front...
789
I am about to buy the Pioneer DMH-WT76NEX head unit. It has one USB Type C output. My Honda has an HDMI port, 2 USB-A ports, and one charger...
Haters are going to hate. It usually goes back to something personal. He would probably take it in his dirty penny to have a full Sundown sub and...
24
5K
monkeyman
monkeyman
los angeles,ca
irishpride
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
