Thoughts on this amp please
>>SQL<<
I did some trading and ended up with this amp
Rockford T10001bd
I picked it up to ran a pair of Skar 12's
I will be running it at 1 ohm
I have good electrical (big 3, HO Alt)
The person I got it from said the Birth Sheet said it did 1,500 watts @ 1 but he did not include that with the amp.
I was going to run an AP 1300 but sold that when i got this amp.
I will say this thing has some weight to it, the AP boxed for shipping was just over 6.5LBS
This amp by itself weights just under 16.5LBS
Anyway what do you think I will get out of this amp and do you think it is a solid piece.
Thanks everyone.
I didn't list what I traded for the amp.
What I traded was BNIB and sells for $300 at the store
I got it as part of a larger deal so am not really sure how much I have into it.
Rockford T10001bd
Thanks everyone.
1200 watts plus.
I did some research on the amp on a few other forums and 1,400 seems about right.
That is perfect as I really want to give around 700 to each of my Skar's.
Now I just need to make sure my electrical is good enough.
I am bypassing the ELD in my Honda, installing an HO Alt, Big 3 is done, and have voltmeter monitoring the rear dist block installed in the dash.
I am installing the amp most likely monday unless my Box Shows up here Friday.
Thanks for the answers.
if your electrical can hold at 14.4 i would say minimum of 1200 watts after rise.
---------- Post added at 11:05 AM ---------- Previous post was at 11:04 AM ----------
rms
wait ELD? wtf does that do when bypassed? please respond.
>>SQL<<
>>SQL<<
USA
CAT MAN
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
