This Box Just Cant Be Right or Is It????????
SmartOJ
im going to summarize this into the shortest story az possible. this is my second box ive had built buy this guy since im trying to get away from prefab. the first box i had built was for 2 15's with comp vr speakers in it. I cant deny at all that it absolutely slammed, and when it came to low notes it was something serious. Sounded like i had twice the powere and twice the speakers. He said the box wuz 10 cubes but according to several calculators with just outer dimensions not including port displacement was 8.1 cubic feet. the box was still huge as hell so i decided to downgrade to 12's, have another box made so it can still slam.
i bought 2 audiobahn 1200v 12's off ebay. I know they are audiobahn but hey ive dealt with them before and had no regrets. but anyway once the box was ready and speakers mounted, the subs were hitting hard as hell on high notes. but after trying to play some songs that could show me how low they can get, they blew complete booty. its like when i play low stuff its like lows are non existent, the sub just sounds really nasty when it drops, but it hits like 4 12's when playing non below 50hz or so. so im basically trying to see if i got ripped off? or maybe the box is too small or too big? He tuned the box too high? or is the box ok , but the subs just ****??? and also the 15" box was not built to spec for the vrs, it was just a general box.. I need lots of input, because i dont feel too happy right now.
The box is constructed of 3/4" mdf.the outer dimensions of the box is 36"W by 14.5"H by 21.75"D.
and for the port its 5 1/2" wide. im not good at describing measurement of ports so ill describe it to the best of my ability. If u think about the inner L-shape that makes the port INSIDE the box it is 15 1/4" from the front of the box then it is 6" after the 90 degree angle. he also told me that the box was tuned to 37hz. so tell me if hes been lying to me, and the 15 box just happened to sound good or should i not return to him.thanks alot guys
that sounds about right... and dont forget, a lot os 12's, especially cheaper ones *cough cough* just dont have the "low" in em, thats why they're cheap //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
well not to justify for audiobahn i had 2 audiobahn 1500w's and they were dropping in a prefab sealed box. thats the only reason i bought the 12's because ive dealt with them b4 and had no complaints.i have to ball on my own level bcuz right now i just cant see myself spending 4-500 bucks on just subs right now. if I could I would, but i cant so i aint......................
ok i provided all the info and getting alot of views but no replies. where did all the box experts go??? and is that box really tuned to 37 of is it higher
results.
enclosure before displacement = 5.25cuft
enclosure after displacement = 4.292cuft
port displacement =.963cuft
enclosure tuning =39.82Hz
results are aproximations only since i have no idea what your sub displacements are.
i would rather have an enclosure with an F3 of 25Hz, and tuned lower. it would bring the lows allot stronger and louder.
PS: even if the subs where crap they would still put out a decent amount of bass even at lower freqs, what you get with lower end subs. is distortion, lower power handling, and bottoming out. among others. but a well designed enclosure would bring the best out of most crapy subs.
thanks for that info. so isnt 2 cubes per sub after displacement still pretty good in general for a ported 12 to get low? and i believe that 15 box wasnt tuned lower than this one. i think he said it was tuned to 37 also. So do we box to the conclusion that the box wasnt right or the subs just cant get the job done. I want to keep this box becuz i dont have the money to get another one made and this one is well constructed. but i can buy different subs eventually if the subs are the culprit.when i play low stuff (30 something hz range) the subs move like crazy but they sound like they cant hang but not distorted and like i have the subsonic filter on but i dont. just want to conclude if its box or subs. and pleas dont bash the sub just becuz its audiobahn. i need real explanations. thanks guys
could you provide the model of the sub youre using that would help to answere the questions youre having.
that will help find out if your enclosures where modeled around the subs. or did he just use generic values to build you the enclosure. and we can also find out . what the theorical output should be of the sub on the enclosure and farthere troubleshoot. your issue.
laters
well i can tell u right off the bat that it ws built off generic values and not sub specific. the sub is a audiobahn AW1200V model. and also once u figire everything out could u name some inexpensive but not cheap subs that would perform well with my current box. thanks
SmartOJ
SmartOJ
Tennessee
SmartOJ
