This alternator sound good?
Have you upgraded the Big 3. If not that would be the first thing that I would do.
It sounds like you have other problems going on, I am running like 2000 watts and have no dimming on stock alt.
So upgrade the Big 3, have local autozone check you alt and bat to make sure they are in good shape. You should not have a dimming problem with 600 watts.
I have the same question... kinda. I have a 95 AMP alt and I get massive dimming at loud volumes. I ahve done the big 3, and I have stock battery. Do u think a new batt will help me out NOTICABLY? As in, not as bad dimming?
i doubt it on the battery unless your mre then sure your battery isnt charging corectly
I'll get this checked sometime. Where do they do this for FREE? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif???
I'm uncertain as to what kind of amperage drain your charging system is going through, age of your current battery etc, however in my case, a new battery [Optima YT] made a VERY noticeable difference.
U just replaced the stock with the Optima? Or are u rinning 2 batts now?
Like said above, I dont beleive that a new battery is going to help at all unless your current battery is actually bad. Go get it tested before you get another one.
A battery will help however if you like to run your system with your car off.
RollinRemz05
RollinRemz05
Toms River, NJ
Qoob
