Thinking of painting a box, will it look good?
yeah. except i think it would be a little harder to use on the seams.
Alright, thanks for all of the help. I will try to post up some pics of the finished result whenever it gets done(god knows when that will be) so that you guys can criticize my horrible box making skills...
For step one could I use wood putty instead of bondo?
I would be careful about using wood putty. If you do, try not to use too much. On an enclosure I painted, I used wood putty to fill the screw holes and after about a month, they began to rise. Now they're very obvious as you can feel and see them. They were sanded perfectly flat before the primer too.
And what would stop bondo from doing the same thing?
Thats why I prefer bondo.
Home creepo is fine. You just mix it with the hardener and put it on.
I take it the "hardener" will come with the bondo? Sorry for the noob questions...//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I must warn you its a pain in the arse to do all this. I did this with the first box i built. It came out decent at first but it easily scratches. And the workload into painting the box (sanding the bondo) can be the longest part.
Ill carpet any day over paint lol, but good luck to you.
Puppet Master
Puppet Master
Fargo, ND
dbornotdb
