I kind of (note that I did not say that I DO) feel like a d!ck for talking like this in a thread where I am seking for advice, but this is the third post where I really have to wonder if reading comprehension is affected by inhaling too much MDF dust.
FROM THE BEGINNING:
I have a 4 channel amp. It is designed for 50 watts per channel and has 4 channels. Those channels can be bridged. See, I already posted this info...
I am considering a small enclosure (less than 0.4 cubes, if possible) with a single 8" sub that can be run by a 50x4 amp with 2 channels bridged to the sub. Front channels will power a set of CSX 265 components.
Remedial lesson: If I brigde 2 channels into 1 channel, the amp is running at HALF of the impedence of each channel individually. Thus, with a 4 ohm load, the amp will be running at 2 ohms. If I had a 2 ohm load, the amp would be running at 1 ohm. If I have an 8 ohm load, the amp is running at 4 ohms.
I thought that people here already understood this...maybe I was wrong.
On the the driver...
Two 2 ohm VCs in parallel are a 1 ohm load. Two 2 ohm VCs in series are a 4 ohm load. I WANT A 4 OHM LOAD WHEN I BRIDGE MY 3/4 CHANNELS ON THE AMP.
Two 4 ohm VCs in parallel are a 2 ohm load. Two 4 ohm VCs in series are an 8 ohm load. The 2 ohm load combined with bridging the amp will result in the amp running at 1 ohm. I DON'T WANT THIS because it will cook my amp. The 8 ohm load combined with my bridged amp will result in my amp running at 4 ohms. I DON'T WANT THIS because it is not optimizing my amp's capabilities.
A 4 ohm DVC will not give you a 4 ohm load or a 1 ohm load, it's either 2 or 8. I don't know where you're getting this 4 ohm dual sub leaving you at a 1 or 4 ohm load...
Where did I say this? I said that the amp would be operating at 1 ohm or 4 ohms- I never said that the LOAD would be 1 or 4 ohms.
What are you talking about? Why would you bridge it to 8 ohms?
Where did I say this? I stated that if I run two 4 ohm VCs in series that I woudl have an 8 ohm load, and that when bridged to that 8 ohm load, my amp would operate at 4 ohms.
You would want it at 4, where it puts out the most power bridged. And chances are your amp is not stable at 2 ohms bridged so I don't even know why are talking about getting the 2 ohm power?
I already said that the amp cannot run at 1 ohm (which results from 2 channels being bridged into a 2 ohm load). You called it 2 ohms bridged, but it is saying the same thing. My only mention of it is that the amp CANNOT run safely while bridged into a 2 ohm load...in other words, the amp can't run at 1 ohm.
I'm guessing your amp is 50w x 4 @ 4 ohm, 100w x 4 @ 2 ohm, or 200 watt x 2 @ 4 ohm bridged. Meaning if you bridged 2 of the channels, you would see 200 watts @ 4ohms, which is what you want. What's the model # of the amp?
I DID say this...several times.
Amp is a Boston Accoustics GTA-504...
