things to know about bridging
brafferty
idaho
decided to try bridging just a moment ago, and a few things i noticed and am curious are normal,and also other things to keep in mind would be nice.
1. The R/L Balance now doesnt mute one side, but instead makes one more quite while increasing the other.
2. The F/R Fader seemed to do the same thing, maybe it muted one of them this time around not sure.
3. now that i an running just 2 speakers whats going to change about tuning?
4. Does my Amps TLA become useless now?
Thanks in advanced!
It sounds like you might have a channel crossed up somewhere.
Maybe a front and rear.
If you're bridging from 4 ch input to 2 channel output and your front/rear left is working together and front/rear right is working together then balance should work like you'd expect it to. You should be able to balance from all one side to all the other.
When you fade -- center will be the loudest. All front and all rear will both give you a reduced volume.
Oh ok I might have an idea what happened, I bridged channels 1/2 together, I probably need to do 1/3? I just followed the diagram I found online for my amp and it looked like it said to bridge 1/2 and 3/4
you're supposed to bridge 1/2 together, but then you'll also need to put only left or right speakers and left or right rca ins isolated to the bridged channels
Oh ok so I only need 2 rcas? Or 2 per side
you need left rcas going to your bridged left side and right rcas going to your bridged right side split them if necessary
Ok so far it sounds and works good! Gunna go crank it on a drive and I'll be back with results
just think about it logically you need to have the left isolated from the right treat each bridged channel as one single channel basically a 2 channel amp with 4 rca inputs
**** this is interesting! It didn't get much louder, but I feel like I hear parts of the song I didn't before ? It's a little echoes around the car but im sure once I set the DTA settings that'll go away, and it's interesting not having sound behind you! It really does make it more concert like
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
984
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
brafferty
brafferty
idaho
brafferty
