THE Thread
Originally posted by denim what does that symbol mean? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I think it means f-u. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Hey denim dan, what do you think my stock alternator in my 93 explorer (4.0) is? I ask because you have an explorer, right?
Originally posted by BonusBobo I think it means f-u. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I thought they were 90 ampers or 100, but i upped mine to 150, definatley worth it, check out MR Alternator.com good prices but I have heard mixed opinions on them so far, but 200 for 200 for an Ex //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by denim I thought they were 90 ampers or 100, but i upped mine to 150, definatley worth it, check out MR Alternator.com good prices but I have heard mixed opinions on them so far, but 200 for 200 for an Ex //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Impressive. How hard are they to install? I know zero info about installing engine parts. But that probably goes with the fact that I don't hit near as many deers as you do. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Bro they are very simple to install. It should come with instuctions how to do it. Shouldnt take YOU more then 45minutes. I have changed and added a 2nd alt to friends cars and mine. You could take it to a shop and they will probably charge you 50$ and tell you it takes an hour. It on average takes 15minutes. Just take a look at yours one day and you will notice probably 3 bolts. I dont really want to get into how you do it, because it would be rather long. So I will just give you 3 pointers.
1. there should be a bolt holding it up. If you undo that bolt it kinda drops down. That takes the pressure off the belt that turns the pulley.
2. Undo the rest of the bolts and take the belt off the pully.
3. Make sure you unhook the electric plug before you try to pull the alt out.
Originally posted by BonusBobo Impressive. How hard are they to install? I know zero info about installing engine parts. But that probably goes with the fact that I don't hit near as many deers as you do. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hahah thanks, but yeah they are not too hard to install the trick is your engine timing, because it is on the fan belt, but if your worried it is worth it to get a shop to install it for you, but the current upgrade it worth it
Like I said it should be about 50$ done in no more then an hour and a wondeful type upgrade. I would recommend this as your number 1 choice instead of a cap, battery/isolator combo...its simple if you have the right charge system the rest is a waste of time and money.
exactly, everything else is for storing current, but if you can produce more, storing it does not matter //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
alright, thanks a lot guys. I'm feeling more gung ho on getting a 200A one, now. I will need it if I go for a 1500W Hifonics //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
RangerMan
Premium Member
Premium Member
RangerMan
NC
x2o
vegang
vegang
