The strongest best battery
Like is 1 200ah battery better then 4 50ah batteries? Cause what it's 55ah per 1k so I would need 500ah in batts or could I get a couple of the 200ah batteries and be done with it cause lacking in space and lacking on battery knowledge
put the biggest dry cell batt in that you can fit, the higher the cca rating the better
---------- Post added at 11:50 PM ---------- Previous post was at 11:49 PM ----------
optima, orbital, odessey, kenetik ect
Cca doesnt mean much in car audio application ..u want high ah and good rc....no matter whether u get 1 500ah batt for 5 100ah batts the size probably wont be much diff ..and running that much power batteries are not something to skimp on
What's a good rc?
I run three kinetic hc600's in the back right cubby hole of my eclipse and they do well for me. I used this size because of the space problem back there. I run power wires to the front and ground them to a cleaned spot on the strut and it all works really well.
bgordon
160db bound !!!
bgordon
Central Kentucky
bgordon
