the right amp for sub
well lets put it this way. the amp i'm lookin at is $100 and the sub is $60-$70. this is going in a 2002 s-10 regular(single) cab. so i have VERY limited space. i want to stick with a single sub setup most likely 10". but i really dont want to go with any of the shallow mount subs. but yea, not much space and not much money to work with. i'm ok with it being cheap i know i won't get much. somethin's better than nothin'.
Gonna be nearly impossible to buy anything worth having with that kind of money, dude. If you had $200-ish you could get this stuff.
subs - RWE-204 - MB Quart 8" 300 Watt DVC Subwoofer (2 of those)
amp - MB Quart DSC 500.1 500W RMS Monoblock Discus Series Amplifier w/ Remote Bass Level Control
This is another option, and it's a little cheaper.
sub - REF-TM12.2 - 12" Tidal Audio Subwoofer Dual 2 Ohm OEM by Image Dynamics
amp - DSC-280 - MB QUART DSC-280 2CH CAR AMPLIFIER CAR AMP DSC280 - UGotADeal.com
Like I said, you're going to need to put back a few more dollars if you want to buy anything even remotely decent...unless you're willing to buy used stuff on craigslist or the classifieds...
if you wire that MBQ down to 1ohm on that MBQ amp, you would need to be careful with the gain. That would be a decent setup for entry level, but not much more. If you just wish to add some semblance of bass to your truck, it will do the trick
In a good box it will probley sound clean. It likely will not be over 132-133db, but its would be enough to satisfy the bass requirement of music. There is nothing wrong with that equipment if your on a tight budget
zero*ego
zero*ego
Lafayette,IN
kr15
