I'm talking dedicated midbass in a 4-way active set up.You consider them better than the exclusive's then. Are you talking 3-way, andwhat crossover point?
Maybe not output, but could possibly sound better than a single 8". I have this theory that lower xmax woofers for this purpose sound better than higher. //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gifA pair of those should IMO match the output of a single SLS 8.
Don't understand your point. Wire the 6.5's in series to show the amp an 8 ohm load?yeah but the 6.5's are also 4 ohms.. the 8's are 8.
well i didnt think it would be "halved" but i did look at it as a loss, and now that i do think about it.. the more i realize your right, the more i realize how it'd prolly be more like 1.5 or 2 db's "at most".. the your ear probally wouldnt hear much of a difference anyway. hmmThe 6.5" is 68.5 dB and the 8" is 87.2 dB (2.83V/M).
Well if you're caught up on the 4 ohm vs 8 ohm and halving or doubling the power type of thinking, then my point is that it's not something to be concerned about. In other words, "powering 8 ohms" isn't like you'll get half the output than you would "powering 4 ohms". It just doesn't work that way. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
You're better off, as you alluded to, being concerned with constructing a proper baffle and maximizing the install than the nominal impedance.
